SPAUSEFACETRES system variable
使用 FACETRES 系统变量
Specifies whether the FACETRES system variable will be used instead of normal tolerance. Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | On |
