SPLINESEGS system variable
Spline segments
Specifies how many line segments are to be generated for each spline-fit polyline (spline option of the PEDIT command). Values between -32768 and 32768 are accepted. With a negative value a fit-type curve is applied. A fit-type curve is composed of arc-segments, which yields a smoother curve, but it takes longer to generate.
Tipo:
Breve
Salvato in:
Disegno
Gamma:
-32768 to 32767
Valore predefinito:
8
