SRCHPATH system variable
Support file search path
Specifies the folder(s) in which BricsCAD should look for text fonts, customization files, plug-ins, drawings to insert, linetypes, and hatch patterns that are not in the current folder. Search paths are separated by semicolons (;).
Solo-BricsCAD
Tipo: | Stringa |
Salvato in: | Registro di sistema |
