SRCHPATH system variable
支持文件查找路径
Specifies the folder(s) in which BricsCAD should look for text fonts, customization files, plug-ins, drawings to insert, linetypes, and hatch patterns that are not in the current folder. Search paths are separated by semicolons (;).
BricsCAD only
Type: | String |
Saved in: | Registry |
