SSLOCATE system variable
Sheet set locate
Specifies whether BricsCAD will try to locate and open a sheet set for the drawing that is being opened.
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | On |
Valori possibili: |
Off (0): Don’t open a drawing's sheet set with the drawing On (1): Open a drawing's sheet set with the drawing |
