SSLOCATE system variable
Sheet set locate
Specifies whether BricsCAD will try to locate and open a sheet set for the drawing that is being opened.
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t open a drawing's sheet set with the drawing
On (1): Open a drawing's sheet set with the drawing
