SSLOCATE system variable
图纸集查找
Specifies whether BricsCAD will try to locate and open a sheet set for the drawing that is being opened.
Type: | Boolean |
Saved in: | Registry |
Default value: | On |
Possible values: |
Off (0): Don’t open a drawing's sheet set with the drawing On (1): Open a drawing's sheet set with the drawing |
