SSMAUTOOPEN system variable
图纸集管理器自动打开
Specifies whether or not BricsCAD displays the Sheet Set Manager when a drawing is opened that is associated with a sheet set. SSMAUTOOPEN and SSLOCATE must both be switched on to display the sheet set automatically.
Type: | Boolean |
Saved in: | Workspace |
Default value: | On |
Possible values: |
Off (0): Don’t open sheet set panel automatically On (1): Open sheet set panel automatically |
