SSMAUTOOPEN system variable
Sheet set manager auto open
Specifies whether or not BricsCAD displays the Sheet Set Manager when a drawing is opened that is associated with a sheet set. SSMAUTOOPEN and SSLOCATE must both be switched on to display the sheet set automatically.
Type:
Boolean
Saved in:
Workspace
Default value:
On
Possible values:
Off (0): Don’t open sheet set panel automatically
On (1): Open sheet set panel automatically
