SSMSTATE system variable
Sheet set manager state
Specifies if the Sheet Set Manager is active or not.
只读
Type: | Short |
Saved in: | Not saved |
Range: |
0 to 1 |
Default value: |
0 |
Possible values: |
0: Sheet Set Manager is not active 1: Sheet Set Manager is active |
