SSMSTATE system variable
Sheet set manager state
Specifies if the Sheet Set Manager is active or not.
Read-only
Type:
Short
Saved in:
Not saved
Range:
0 to 1
Default value:
0
Possible values:
0: Sheet Set Manager is not active
1: Sheet Set Manager is active
