STANDARDSOPTIONS system variable
Standards validation options
Options to control the procedure of checking standards. The value is stored as a bitcode using the sum of the values of all selected options.
Type: |
Short |
Saved in: |
Registry |
Range: |
0 to 3 |
Default value: | 0 |
Possible options: |
1: Fix non-standard object properties automatically 2: Show ignored problems |
