STARTUP system variable
Startup
Specifies the display of the Create New Drawing and Startup dialog boxes.
Type:
Short
Saved in:
Registry
Range:
0 to 3
Default value:
3
Possible values:
0: Display the Select Template dialog box, or use a default drawing template file (set in the BASEFILE system variable)
1: Display the Startup and the Create New Drawing dialog boxes
2: Display the Start page
3: Display the Start page (with ribbon preloaded)
