STRUCTURETREECONFIG system variable
Structure Tree Configuration
Name of the active Structure Tree configuration file. SRCHPATH is used for finding the file. Loading a different CST file than the default file changes the way that the STRUCTUREPANEL command presents drawing data.
Solo-BricsCAD
Tipo: | Stringa |
Salvato in: | Area di Lavoro |
Valore predefinito: |
"default.cst" |
