STRUCTURETREECONFIG system variable
Structure Tree Configuration
Name of the active Structure Tree configuration file. SRCHPATH is used for finding the file. Loading a different CST file than the default file changes the way that the STRUCTUREPANEL command presents drawing data.
BricsCAD only
Type: | String |
Saved in: | Workspace |
Default value: |
"default.cst" |
