SURFTAB1 system variable
Surface tabulation 1
Specifies the number of tabulations to be created for RULESURF and TABSURF. Also defines the mesh density in the M direction for REVSURF and EDGESURF.
When extruding entities with arc segments: the SURFTAB1 system variable divides them in a number of equal length intervals.
When revolving entities: the SURFTAB1 variable controls the number of segments of the revolution surface.
Type:
Short
Saved in:
Drawing
Default value:
6
