SURFTYPE system variable
Surface-fitting type
Specifies the surface-fitting type to be used when the Smooth option of the PEDIT command is executed.
Tipo: | Breve |
Salvato in: | Disegno |
Gamma: |
5 to 8 |
Valore predefinito: |
6 |
Valori possibili: |
5: Quadratic B-spline surface 6: Cubic B-spline surface 8: Bezier surface |
