SURFTYPE system variable
曲面拟合类型
Specifies the surface-fitting type to be used when the Smooth option of the PEDIT command is executed.
Type: | Short |
Saved in: | Drawing |
Range: |
5 to 8 |
Default value: |
6 |
Possible values: |
5: Quadratic B-spline surface 6: Cubic B-spline surface 8: Bezier surface |
