SURFTYPE system variable
Surface-fitting type
Specifies the surface-fitting type to be used when the Smooth option of the PEDIT command is executed.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
5 to 8 |
| Default value: |
6 |
| Possible values: |
5: Quadratic B-spline surface 6: Cubic B-spline surface 8: Bezier surface |
