SVGBLENDEDGRADIENTS system variable
SVG 混成渐层
Use blended gradients for complex gradient fill. The use of complex gradient fills makes the file size larger.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Default value: | Off |
Possible values: |
Off (0): Don't use blended gradients. On (1): Use blended gradients. |
