SVGBLENDEDGRADIENTS system variable
Svg Blended Gradients
Use blended gradients for complex gradient fill. The use of complex gradient fills makes the file size larger.
BricsCAD only
Type:
Short
Saved in:
Preference
Default value:
Off
Possible values:
Off (0): Don't use blended gradients.
On (1): Use blended gradients.
