SVGGENERICFONTFAMILY system variable
SVG 通用文字样式
Font to substitute if the correct one is missing.
The following generic font families are supported in SVG: serif, sans-serif, cursive, fantasy, monospace.
- Sans-serif - fonts without serifs, like Arial
- Serif - fonts with serifs, like Times Roman
- Cursive - fonts that look handwritten
- Fantasy - unusual fonts
- Monospace - fonts where each character takes up the same space (non-proportional spacing), such as Courier
BricsCAD only
Type: | Short |
Saved in: | Preference |
Default value: |
0 |
Possible values: |
0: sans-serif 1: serif 2: cursive 3: fantasy 4: monospace |
