TEXTEDITMODE system variable
Text edit mode
Specifies whether text editing commands (DDEDIT) automatically repeat entity selection or not.
Type:
Short
Saved in:
Registry
Range:
0 to 2
Default value:
0
Possible values:
0: Multiple edit mode (command repeats until canceled)
1: Single edit mode (command ends after editing one text entity)
2: Automatic edit mode (single if editing preselected text, multiple otherwise)
