TEXTEVAL system variable
Text evaluation
Specifies the method of evaluation for the Command line text strings. When the TEXTEVAL system variable is set to 1, this command evaluates LISP expressions:
Text: (* pi 2)
The result of the equation (pi x 2) is placed as text: 6.283185
Type:
Short
Saved in:
Not saved
Range:
0 to 1
Default value:
0
Possible values:
0: All responses to prompts for text strings and attribute values are taken literally
1: Text starting with '(' or '!' is evaluated as an lisp expression, as for nontextual input
