TEXTFILL system variable
文字填实
Specifies whether TrueType fonts are either filled or outlined when exporting with the PSOUT command and in renderings.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 1 |
Default value: |
1 |
Possible values: |
0: Display text as outlines 1: Display text as filled images |
