TRIMMODE system variable
Trim mode
Specifies whether the length of the selected entities or polyline segments for chamfers and fillets are adjusted (trimmed or lengthened).
Type: | Boolean |
Saved in: | Registry |
Default value: | On |
Possible values: |
Off (0): Don’t trim selected edges to the endpoints of chamfer lines and fillet arcs On (1): Trim selected edges to the endpoints of chamfer lines and fillet arcs |
