UCSAXISANG system variable
UCS axis angle
Specifies the default angle, in degrees, for rotating the UCS around its X, Y, or Z axis, using the UCS command.
Type: |
Real |
Saved in: | Registry |
Range: |
5 to 180 |
Default value: |
90 |
