UCSAXISANG system variable
UCS axis angle
Specifies the default angle, in degrees, for rotating the UCS around its X, Y, or Z axis, using the UCS command.
Tipo: |
Reale |
Salvato in: | Registro di sistema |
Gamma: |
5 to 180 |
Valore predefinito: |
90 |
