UCSAXISANG system variable
UCS axis angle
Specifies the default angle, in degrees, for rotating the UCS around its X, Y, or Z axis, using the UCS command.
| Type: |
Real |
| Saved in: | Registry |
| Range: |
5 to 180 |
| Default value: |
90 |
