UCSDETECT system variable
UCS detect
Specifies the dynamic UCS. The dynamic UCS is a temporary UCS that is automatically activated when the cursor hovers over a 3D solid's face or 2D entity. A negative value is the same as 0, but helps in storing the earlier value. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Registry
Range:
-3 to 3
Default value:
1
Possible options:
negative: Disable dynamic UCS
1: Enable for faces of 3D solid and regions.
2: Enable for 2D entities
