UCSFOLLOW system variable
UCS follow
Specifies whether a plan view (A top view zoomed to extents) is generated automatically whenever the UCS changes. It is recommended to switch UCSDETECT off in this case.
Tipo: | Booleana |
Salvato in: | Disegno |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Don’t show plan view when changing UCS On (1): Show plan view when changing UCS |
