UCSORTHO system variable
UCS orthographic
Specifies whether or not the related orthographic UCS setting is activated automatically when selecting an orthographic view with the -VIEW command or the LookFrom widget (unless NAVVCUBEORIENT is set to UCS).
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): When an orthographic view is selected, don’t automatically activate the related orthographic UCS
On (1): When an orthographic view is selected, automatically activate the related orthographic UCS
