UCSORTHO system variable
UCS orthographic
Specifies whether or not the related orthographic UCS setting is activated automatically when selecting an orthographic view with the -VIEW command or the LookFrom widget (unless NAVVCUBEORIENT is set to UCS).
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): When an orthographic view is selected, don’t automatically activate the related orthographic UCS On (1): When an orthographic view is selected, automatically activate the related orthographic UCS |
