UNDOCTL system variable
Undo control
Specifies the state of the UNDO command. The value is stored as a bitcode using the sum of the values of all selected options.
Read-only
| Type: | Short |
| Saved in: | Not saved |
| Default value: |
5 |
| Possible options: |
0: Undo off 1: Undo on 2: Only one command can be undone 4: Auto is turned on 8: A group is currently active |
