USECOMMUNICATOR system variable
Use Communicator
Indicates that a Communicator license was activated. If the license is changed, the new level comes into effect after restarting the program.
- 0: no license, Communicator import and export formats are not available.
- 1: trial, runs Communicator in trial mode, expiring after 30 days.
- 2: full, runs the full communicator import-export set.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Preferenza |
Gamma: |
0 to 2 |
Valore predefinito: |
1 |
Valori possibili: |
0: Not using Communicator 1: Using Communicator Trial 2: Using Communicator |
