USECOMMUNICATOR system variable
使用Communicator
Indicates that a Communicator license was activated. If the license is changed, the new level comes into effect after restarting the program.
  • 0: no license, Communicator import and export formats are not available.
  • 1: trial, runs Communicator in trial mode, expiring after 30 days.
  • 2: full, runs the full communicator import-export set.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 2
Default value:
1
Possible values:
0: Not using Communicator
1: Using Communicator Trial
2: Using Communicator
