USENEWRIBBON system variable
Use the new Ribbon
Controls whether the new Ribbon is used.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Disable the new Ribbon
On (1): Enable the new Ribbon after restart
