USESTANDARDOPENFILEDIALOG system variable
Use standard open file dialog (Windows)
Specifies whether to show an additional folder in the file dialog for the open, save as and insert commands.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | Off |
