VIEWMODE system variable
View mode
Specifies the current viewport's View mode. The value is stored as a bitcode using the sum of the values of all selected options. If 'Front clip not at eye' (16) is on, the front clip distance (FRONTZ) sets the front clipping plane. If off, the front clipping plane passes through the camera point (vectors behind the camera are not displayed). This flag is ignored if the front-clipping bit (2) is off.
Read-only
Type:
Short
Saved in:
Drawing
Range:
0 to 31
Possible options:
0: Turned off
1: Perspective view active
2: Front clipping on
4: Back clipping on
8: UCS Follow mode on
16: Front clip not at eye
