VOLUMEPREC system variable
Volume precision
Specifies the number of decimal places displayed for volumes when the volume bit of PROPUNITS is on. If negative, LUPREC (Linear Unit Precision) is used.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: |
-1 to 8 |
Valore predefinito: |
-1 |
Valori possibili: |
-1: Use LUPREC 0 1: 0.0 2: 0.00 3: 0.000 4: 0.0000 5: 0.00000 6: 0.000000 7: 0.0000000 8: 0.00000000 |
