VOLUMEPREC system variable
体积精确度
Specifies the number of decimal places displayed for volumes when the volume bit of PROPUNITS is on. If negative, LUPREC (Linear Unit Precision) is used.
BricsCAD only
Type: | Short |
Saved in: | Registry |
Range: |
-1 to 8 |
Default value: |
-1 |
Possible values: |
-1: Use LUPREC 0 1: 0.0 2: 0.00 3: 0.000 4: 0.0000 5: 0.00000 6: 0.000000 7: 0.0000000 8: 0.00000000 |
