VPMAXIMIZEDSTATE system variable
Viewport maximized
Displays a value to indicate whether the viewport is maximized. You cannot plot or publish when the viewport is maximized.
AutoCAD only
Read-only
Type:
Boolean
Saved in:
Not saved
Default value:
Off
Possible values:
Off (0): Viewport is not maximized
On (1): Viewport is maximized
