VPMAXIMIZEDSTATE system variable
Viewport maximized
Displays a value to indicate whether the viewport is maximized. You cannot plot or publish when the viewport is maximized.
AutoCAD only
只读
Type: | Boolean |
Saved in: | Not saved |
Default value: | Off |
Possible values: |
Off (0): Viewport is not maximized On (1): Viewport is maximized |
