VPMAXIMIZEDSTATE system variable
Viewport maximized
Displays a value to indicate whether the viewport is maximized. You cannot plot or publish when the viewport is maximized.
AutoCAD only
Read-only
| Type: | Boolean |
| Saved in: | Not saved |
| Default value: | Off |
| Possible values: |
Off (0): Viewport is not maximized On (1): Viewport is maximized |
