VTENABLE system variable
Enable view transitions
Specifies whether animated view transitions are enabled for zoom/pan and/or for view rotation operations. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 7 |
| Default value: |
3 |
| Possible options: |
1: For zoom/pan 2: For rotation 4: For unattended mode |
