VTFPS system variable
查看转换最小FPS
Specifies the minimum FPS (frames per second) required for enabling animated view transitions. That is 7 by default, which means that the redraw time should take less than 143 (=1000/7) milliseconds. If the computer is not capable to redraw the view fast enough, no animation will be available.
Type:
Short
Saved in:
Registry
Range:
1 to 30
Default value:
7
