WRITESTAT system variable
Write status
Shows the state in which a drawing is opened: read-only or that it can be written to. This variable is used in lisp to determine the write status of drawing.
Read-only
Type: | Boolean |
Saved in: | Not saved |
Default value: | On |
Possible values: |
Off (0): Can’t write to the drawing On (1): Can write to the drawing |
