XFADECTL system variable
参照编辑淡出控制
Specifies the fading level for references which are edited in-place. This setting affects only the entities that are not being edited in the reference. Values between 0 and 90 are accepted.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 90 |
Default value: |
50 |
