XLOADCTL system variable
Xref load control
Not supported yet. Specifies xref demand-loading and determines whether a copy or the original drawing is opened.
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: |
0 to 2 |
Valore predefinito: |
1 |
Valori possibili: |
0: Turn off demand-loading; the entire drawing is loaded 1: Turn on demand-loading; referenced drawings are kept open and locked 2: Turn on demand-loading; copies of referenced drawings are opened and locked; referenced drawings are not locked |
