XLOADCTL system variable
Xref load control
Not supported yet. Specifies xref demand-loading and determines whether a copy or the original drawing is opened.
Type:
Short
Saved in:
Registry
Range:
0 to 2
Default value:
1
Possible values:
0: Turn off demand-loading; the entire drawing is loaded
1: Turn on demand-loading; referenced drawings are kept open and locked
2: Turn on demand-loading; copies of referenced drawings are opened and locked; referenced drawings are not locked
